What would be better to get? An Inverter with batteries for my current PC? Or a Laptop?
1 hour ago, Dragamore said:So I live in South Africa where they have been putting the power off for about 8 hours every day. I work from home and it's starting to effect my work... there is no way I will be able to afford solar so I feel like my options are between the following
- Buy a Laptop that can handle audio editing and some light video editing
- Or Buy an inverter with batteries that can power my current PC
- A generator is not an option since it will be way to expensive to keep it running
I don't know enough about inverters to really make the decision on my own and when it comes to laptops I'm pretty clueless. Also with me living where I do Laptops are a lot more expensive than in America and Europe so it might be hard to help me decide on one but my Budget is just under $2000.
I need my pc or laptop to last at least 6 hours
If I need to post any extra info then I'll do that xD
Looks like the best option will be to get a laptop, now I must go scrounge through Reviews and forums to find out what laptop xD
Thanks everyone
