push pull config with same fan or different ?
Solved by Blue4130,
1 hour ago, lisadavis said:so lianli unifan 120 + deepcool fk 120 fan work on push/pull and no need to buy another pack of lian li right?
Ideally you'd want similar pressure fans, but in the end it really isn't going to make much if any difference.
l3eyond ·
1
Serendipity1344 ·
Posted in Graphics Cards4 -
1
1
5
1
toxic_worper ·
Posted in New Builds and Planning9
