I have received a pc for Christmas and having trouble with display. Inside the pc there is a debug led dram. I am starting to think some parts are not Compatible with the Motherboard. The specs are ASUS GTX 1660 TI, RYZEN 5 5500 and Concoir Vengeance Lpx ram. Please help
https://linustechtips.com/topic/1477686-problem-with-ram-on-b550m-pro/
And your motherboard is?
Welcome to the forums!!!
What slots are the RAM installed in? Is this a prebuilt or did someone build this to gift you?
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
3 minutes ago, Cruzz said:
The ram is in the second and fourth slot. And a family member gifted it to me
If you feel comfortable, can you remove just one stick of ram and try turning on the computer?
Ok that's good.
Do you know if the motherboard BIOS was updated to support the 5500?? It may need a BIOS update first.
Sadly attachments in the forum might be broken as I am not able to download the file. Care to explain what happened by text?
Yep. I removed one ram stick and still the same thing happened as before. no display and dram light is still on
7 minutes ago, Cruzz said:
Yea that might be it though I don't know how to do a bios update
You'll need to follow page 46 of the manual and update the BIOS using a USB thumb drive.
E7C95v1.7.pdf (msi.com)
Thank you. Im going away for the weekend and wont be able too run the bios update. ill reply when I get back home.
