AIO Choice for 7700x build.
danb8621
I am going to begin building a 7700x build tomorrow and was hoping someone could let me know their thoughts on the DeepCool LS520 240mm AIO. I am told that these new ryzens are running hotter then the prior models, I am coming from a 5800x that had a custom ZMT EK setup cpu only.  I am looking to make life a little neater with an AIO.  Just am not sure if the DeepCoolLS520 is a good fit.  I do not overclock anything and never will.
MOBO - Strix b650 -e
RAM - G Skill 6000mghz 32gb (2sticks)
GPU - Asus TUF 3080ti
PS - RM850x
Case - Antec DP502
Thanks, Happy Holidays.
The 7700x is hotter than last gen but not hot enough to need an AIO. Personally, I’d go air cooling and avoid the worry of the pump failing.
If however, your heart is set on an AIO though, any 240mm rad will be fine (overkill).
I might be experienced, but I'm human and I do make mistakes. Expand for common PC building advice, a short bio and a list of my components and other tech. I edit my messages after sending them alot, please refresh before posting your reply. Please try to be clear and specific, you'll get a better answer. Please remember to mark solutions once you have the information you need.
Common build advice: 1) Buy the cheapest (well reviewed) motherboard that has the features you need. Paying more typically only gets you features you won’t use. 2) only get as much RAM as you need, getting more won’t (typically) make your PC faster. 3) While I recommend getting an NVMe drive, you don’t need to splurge for an expensive drive with DRam cache, DRamless drives are fine for gamers. 4) paying for looks is fine, just don’t break the bank. 5) Tower coolers are usually good enough, unless you go top tier Intel or plan on OCing. 6) OCing is a dead meme, you probably shouldn’t bother. 7) "Bottlenecks" rarely matter and "Future-proofing" is a myth. 8) AIOs don't noticably improve performance past 240mm.
useful websiteshttps://www.productchart.com - helps compare monitors, https://uk.pcpartpicker.com - makes designing a PC easier.
He/Him
I'm a PhD student working in the fields of reinforcement learning and traffic control. PCs are one of my hobbies and I've built many PCs and performed upgrades on a few laptops (for myself, friends and family). My personal computers include 3 windows (10/11) machines and a TrueNAS server (and I'm looking to move to dual booting Linux Mint on my main machine in future). While I believe I have an decent amount of experience in spec’ing, building and troubleshooting computers, keep in mind I'm not an expert or a professional and I make mistakes.
Favourite Games of all time: World of Tanks, Runescape, Subnautica, Metroid (Fusion and Dread), Spyro: Year of the Dragon (Original and Reignited Trilogy), Crash Bash, Mario Kart Wii
Main PC: https://uk.pcpartpicker.com/user/will0hlep/saved/NByp3C
Secondary PC: https://uk.pcpartpicker.com/user/will0hlep/saved/cc9K7P
TrueNAS Server: https://uk.pcpartpicker.com/user/will0hlep/saved/m37w3C
Laptop: 13.4" ASUS GZ301ZE ROG Flow Z13, WUXGA 120Hz, i9 12900H, 16GB DDR5, 1TB NVMe SSD, 4GB RTX 3050 Ti, TB4, Win11 Home, Used with: 2*ThinkPad Universal Thunderbolt 4 Dock, Logitech G603, Logitech G502 Hero, Logitech K120, Logitech G915 TKL, Xbox Elite Wireless Controller Series 2, Logitech G PRO X Gaming-Headset (with Blue Icepop in Black), {specs to be updated: two monitors}
Other: LTT Screwdriver, LTT Stubby Screwdriver, IFIXIT Pro Tech Toolkit, Playstation 1 SCPH-102, Playstation 2 SCPH-30003, Gameboy Micro Silver OXY-001, Nintendo Wii U WUP-001(03), Playstation 4 CUH-1116A, Nintendo Switch OLED HEG-001, Yamaha RX-A4A Black AV Receiver, Monitor Audio Radius (4*90s, 1*200s, 2*270s, 1*380s), TP-Link TL-SG105-M2, Netgear GS308, IPhone 14 Pro Max 128GB Space Black, Secretlab TITAN Evo (Black SoftWeave Plus Fabric), 2*CyberPower BR1200ELCD-UK BRICs Series, Samsung 40" ES6800 Series 6 SMART 3D FHD LED TV, UGREEN USB 3.2 Gen 2 10Gbps M.2 NVMe SSD Enclosure, SABRENT 3.5" SATA drive docking station
i was actually considering going Air for the first time with a noctua or a deepcool. thank you for acknowledging what i meant about running hot. I have had some other response shun me for that comment when what I meant was exactly how you phrased it....hotter then last gen.  Appreciate your response and advice.
Look at how many people say their Ryzen runs hot with an AIO. Ryzen runs cool with my air coolers.
AMD R7 5800X3D | Thermalright Aqua Elite 360, 3x TL-B12, 2x TL-K12
Asus Crosshair VIII Dark Hero | 32GB G.Skill Trident Z @ 3733C14
Zotac 4070 Ti Trinity OC @ 3045/1495 | WD SN850, SN850X
Seasonic Vertex GX-1000 | Fractal Torrent Compact, 2x TL-B14
My 7900x with a deepcool as500 plus runs cooler then most aios i have seen.
A good quality cooler does go a long way, glad to hear it 🙂
I have a 7900x under a deepcool as500 plus and it runs 40c at idle and mid 70s under a hard load.If you want a aio those new deepcool ones are hard to beat for the price.If you want max cooling arctic cooling aios.
That is exactly the brand I was going with the deepcool ls520 thanks!
The new ls deepcools are in the top 5 coolest aios
i literally slapped on the 240 mm deepcool ls520 today...temps are stable and great! couldn't recommend enough.
I'd love to see a picture of your build when its done.
Absolutely apologies I just saw this!
4 minutes ago, danb8621 said:
The Case is an Antec DP503 and it is the best.  I am coming from a lian li 011 xl with a full zmt ek cpu loop.  It was great but I needed something simpler and smaller for this build.
17 hours ago, andrewmp6 said:
I have the same motherboard and ram but in white
Awesome! I am very happy with it so far I got the CPU,RAM and Mobo as a bundle from microcenter.  I have been trying to figure out how to overclock the RAM but I cant get the system to stay stable with the expo setting so im just leaving it to run at 4800mghz for now.
I left mine running docp and its been happy.Mines only 5200mhz tho.
Ok sounds good I am going to leave well enough alone its running just fine.
