Budget (including currency): 30,000 (PHP)
Country: Philippines
Games, programs or workloads that it will be used for:
  • Occasional Gaming - GTA V, Valorant, NFS, L4D2 (Let's say I am gaming for twice a week) NO STREAMING!
  • Work - zoom, google meet, obs, postman stuffs, coding, and unity
Other details:
  • Here are the list of parts that I will buy: https://pcpartpicker.com/list/WWZ2Mb
  • GPU: GTX 750ti (I am just recycling this since I am not doing any hardcore gaming and it can run the games i've mentioned above)
  • Monitors: 2x 1080p@60hz
  • Storage: 1x SSD 512gb and 1x HDD 1TB (from old pc)
I am not even sure if I should go with the i3-12100 since it is much cheaper, but I go with the i5 since I am not planning to upgrade in the near future except for ram I may upgrade it to 32gb next year. Maybe after 5-8 years?
https://linustechtips.com/topic/1476015-first-build-for-college/
Other details:
I think your IGPu is faster that Gt 750 if you want to play games pick up a used 1080 or just pickup the K variant of that CPU . or you want a all rounder semi gaming rig get a amd CPU its integrated graphics can play most games at 1080p low settings/ 720p Mid settings. i will change the rig like this https://pcpartpicker.com/list/rMvZ3y its a amd CPU no gpu build 5600G can play games here's a gameplay testing. it will be much much better than gtx 750 by a mile. if you want to add in a gpu add either a rx6600 or used gtx 1080 anything below that is basically E-waste. I added a 512 gb ssd as well even then it is less than your intel build btw if you want a gpu you can add something like this https://pcpartpicker.com/product/D9ytt6/asrock-radeon-rx-6600-8-gb-challenger-d-video-card-rx6600-cld-8g
I would go something like this and later on you have open doors for a GPU upgrade RX 6600 XT or 6700 XT.
PCPartPicker Part List
CPU: Intel Core i5-12400F 2.5 GHz 6-Core Processor  ($166.99 @ B&H)
Motherboard: MSI PRO Z690-P DDR4 ATX LGA1700 Motherboard  ($159.99 @ B&H)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($52.99 @ Amazon)
Case: Zalman S3 ATX Mid Tower Case  ($54.99 @ Amazon)
Power Supply: Thermaltake Smart BM2 750 W 80+ Bronze Certified Semi-modular ATX Power Supply  ($74.98 @ Amazon)
Total: $509.94
Generated by PCPartPicker 2022-12-24 02:55 EST-0500
To be an expert is to know more about less.
  • 2014 Build --> FX 8350 4.7GHz {} ASRock Fatal1ty 990FX Killer {} Reference GTX 980 4GB {} 2x4GB 1866MHz HyperX {} Seagate 2TB 7200rpm {} 840 EVO 120GB {} XFX PRO850W {} Noctua NH D14 {} Fractal Define R4 White Windowed
  • 2018 Build --> Ryzen 7 2700X {} ASRock Fatal1ty X470 Gaming K4 {} Gigabyte RTX 2070 8GB {} 2x8GB HX Fury 3200MHz {} Toshiba P300 2TB {} Kingston 480GB A1000 {} Corsair RM750W {} Enermax LIQMAX II 240 {} Fractal Focus G
  • 2021 Build --> Ryzen 9 5900X {} ASUS ROG Strix X570-F GAMING {} ASUS GeForce RTX 3080Ti ROG STRIX OC {} Gigabyte AORUS RGB DDR4 32GB {} Kingston KC2500 M.2 2280 NVMe 2TB {} Seasonic FOCUS GX-1000 {} ASUS ROG Ryujin 240 AIO {} NYXT H710i
  • 2026 Build --> Ryzen 9 9950X3D {} ASUS ROG CROSSHAIR X870E HERO {} ASUS GeForce RTX 5090 32GB ASTRAL LC {} G.Skill TridentZ Royal Neo RGB Silver DDR5 CL28 6000MHz 2x16GB {} Samsung SSD 4TB 9100 PRO M.2 {} Seasonic 1600W PRIME TX Noctua Edition {} Fractal Lumen S36 V2 RGB 360mm AIO {} Fractal Design North XL Charcoal
CPU: AMD Ryzen 5 5600G 3.9 GHz 6-Core Processor  ($107.41 @ Amazon)
CPU Cooler: Cooler Master Hyper 212 RGB Black Edition 57.3 CFM CPU Cooler  ($54.00 @ Amazon)
Motherboard: ASRock A520M Phantom Gaming 4 Micro ATX AM4 Motherboard  ($81.98 @ Newegg)
Memory: Kingston FURY Beast 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($58.12 @ Amazon)
Case: MSI MAG FORGE M100A MicroATX Mid Tower Case
Power Supply: Corsair CX550M (2021) 550 W 80+ Bronze Certified Semi-modular ATX Power Supply  ($69.99 @ B&H)
Total: $371.50
Generated by PCPartPicker 2022-12-24 03:15 EST-0500
You don't need that 750ti with this, you can do a light game with the integrated cpu.
Total: $371.50
is there a future path upgrade for AM4 (I heard that it's not possible to have an upgrade path for amd, correct me if I'm wrong)? Also, the temperature is high for Ryzen 5 3600 (my brother is using this) using a stock cooler. which gave me an impression that amd has a bad heat regulation.
P.S. if the ryzen 5 5600G is better than my gtx 750ti in terms of graphics, I might sell my old pc for an extra bucks to get a new card
Total: $509.94
Sadly, the motherboard is out of my budget and I won't do any OC. for the case and psu, it's hard to find a store that sells a huge variety of brand. thanks for recommending though
No you got wrong information intel is worse at heat management . am4 isn't get any new chips anymore that does not necceraly makes am4 a bad platform the best of the best gaming cpu is still am4 and am5 requires ddr5 and that cost a kidney or two. No new CPUs will be launched for AM4 but You can still pickup a Ryzen 9 5900X (the best allrounder in Am4) or Ryzen 7 5800 X3D(the best gaming CPU). And You have a clear path in Gpu upgrading. And the price will drop for these chips And for 5 or so years you don't really need to upgrade your cpu unless you are into Cpu Heavy  tasks. even you pickup intel they are going to kill lga 1700 later this year. even  Ryzen 7000 maybe amd next year change their word and release the cpu on a new platform you never know .  The Budget friendly option currently is Ryzen 5000. To your Fried Reapply the thermal paste and there is a small slider in side of your cooler saying HIGH LOW  change that button to High. In 99% of use cases amd stock cooler can cool an amd cpu but intel stock coolers generally fail to do so but a good cooler can fix the issue and you really cant complain for about both companies . The IGPU in 5600G (even 3250U in my laptop will beat 700 series with ease ) is faster than 700 series.
got it. since it's a less pricey processor i can squeeze in a good cooler. Tho, I'm not that heavy gaming user. so, overheating is not an issue on my end. Thanks for clarifying
if you dont want to oc or anything you can get the Motherboard @SupaKomputa suggested and get away with that.
Then you don't have to get a cooler you can upgrade that when you find that necessary.
you can upgrade to 5950x or 5800x3d in the future if you want, without changing the motherboard. this gen is still good till 3-5 years.
Ryzen is cooler than Intel in general, with hyper212 it's better.
