@LeParkour012
Yup, if you take the hard drive with the Windows 8.1 out. Then install the other OS on a different HDD. Windows 8.1 will still be on the original hard drive and it will boot from it with no problems when you reconnect it.
Corsair 400R, i7 3770K @ 4.5GHz 16GB, Corsair Vengeance 1600MHz, Gigabyte Z77X-UD5H Motherboard, 240GB Samsung 840 Evo Sata III SSD, 2 x Asus GTX 780 Direct CU2 SLI, Corsair H100i and Corsair AX860i Platinum Power supply.
https://linustechtips.com/topic/147300-hard-drive/#findComment-1967640
As long as the drive with Windows is completely unplugged, it will be safe.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/147300-hard-drive/#findComment-1967657
