Stupid simple drive mount question
Solved by NF-A12x25,
4 minutes ago, -rascal- said:They look like thumbscrews....
Are they threaded or unthreaded?
I'm wondering if CoolerMaster will just send you a bag of them or something...
they are threaded thumbscrew posts that friction-fit into the case’s rubber grommets, and they might send a bag if OP emails them. That said, i also found an STL from someone who got frustrated trying to find one and just 3d printed them
