would 2 140mm fans as pull with 3 120mm as push be beneficial?
Solved by Bombastinator,
The rule is generally you get at most only 20% of the power of the second fan as additional cooling. Twin fans are mostly useful when a single fan runs a bit too fast and creates more noise than is wanted. Sometimes slowing a fan only a little produces a massive nois level change. If the fans are already running slow, or so fast that a second fan won’t help enough, all they do is make more noise to no great useful purpose. 140s have a lot less static pressure than 120s too, so they may not even add much at all.
