Help with compatibility check Ryzen build
Solved by jaslion,
2 minutes ago, Ssapdra said:I see and if I would leave out 3d from equation? I need to doublecheck with friend about the use but gaming and unity is granted.
Case advice sounds good and yeah its gonna be white build.
I mean same story of the cpu. Just get a better gpu regardless that much cpu isnt needed at all.
Rick13 ·
6
popularlion ·
Posted in Troubleshooting4 -
2
CallMe_David ·
FancyPants101 ·
Posted in Troubleshooting1 -
BoBo6107 ·
Posted in LTTStore.com Merch0
