I need a 1150 socket mobo(ATX) ? give me some ideas
And wich one is better 4x4gb Kingston hyper x beast or 4x4gb Gskill sniper ? Or should i go with 2x8 gskill ?
(sorry if my english is bad)
CPU: Intel Core i7 4770k | Motherboard: Asus vi Hero | RAM: Kingstong hyperx fury 16GB (2x8GB) 1866Mhz | PSU:XFX PRO 850w  | STORAGE: WD 1tb blue | COOLER: Corsair H100i CASE: NZXT phantom (black and green) OS: Windows 7 ultimate  (64bit) | VGA : Asus DCU II 780 | Other stuff : Razer Deathadder 2013 edition - Blackwidow Ultimate 2013 - Razer Kraken pro - Razer Goliathus control L - LG 23' IPS full HD
https://linustechtips.com/topic/147182-help/
how much are you willing to spend on the motherboard and just go with 2x8
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/147182-help/#findComment-1965882
I'd go 2x8. that way if you ever wanted more (32gb?) then you can add more without removing current dimms.
I'd just get something from a Z87 mATX range that isn't the bottom end (e.g. MSI G41 series but nothing like ASUS ROG is needed).
https://linustechtips.com/topic/147182-help/#findComment-1965892
Budget?
Are you planning to overclock?
Have a look at Gigabytes Ultra Durable series of 1150 mobos.
As for the RAM, whichever one you like the look of most. They have very similar specifications
My PC:
4670k      GTX 760 ACX      CoolerMaster Hyper 412s      Fractal Design Node 804      G1 Sniper M5      Corsair RM 650      WD Red 1TB     Samsung 840 Evo 120GB
https://linustechtips.com/topic/147182-help/#findComment-1965902
What CPU do you plan on using?
Budget?
what price range? any particular brand? any specific things you want the board to have? and what memory speeds do you want?
I have around 400$ usd for the mobo
I have a 4770k And my case is a NZXT phantom black and green
EDIT : ill use this computer for gaming and maybe some stream.
https://linustechtips.com/topic/147182-help/#findComment-1965928
The Gigabyte G1 sniper 5 will fit perfectly with your case's colours.
Also have a look at Asus's ROG series, and MSIs MPower series
With a $400 budget for the motherboard you can pretty much afford the flagship board from any manufacturer!
My PC:
https://linustechtips.com/topic/147182-help/#findComment-1965957
Old Rig
https://linustechtips.com/topic/147182-help/#findComment-1965987
Mmmm i dont really know that here in my country a 400 usd mobo cost arround 600 usd... our economy just sucks. (argentina)
https://linustechtips.com/topic/147182-help/#findComment-1965989
