GoXLR with Beyerdynamic DT 770 Pro & 990 Pro - interference Noise
This is a common unsolved issue that even the likes of Josh Valour posted an entire video about stating that he had tried everything within his power and he was looking for advice. And he has all the audio hardware so I doubt it's the hardware.
I had this problem and the only thing that would eliminate it was using a balanced connection aka XLR but that was just a bandaid fix for the real problem. Turned out to be a faulty ground in the RCA splitter I had on my single ended side of the chain and it wasn't just downward from the splitter, it made my entire single ended (RCA) solution experience coil whine. Once I took the offending piece of equipment out the sound went away.
What that means for you? I'm unaware because it sounds like you just have the dac/amp and headphones so there is nothing to remove from the loop.
How do you have the goXLR connected to the PC? If it's by USB the most likely suspect would be the goXLR but I honestly can't say what the real problem is, it could be many thing's but somewhere is a ground that isn't happy, that's all I know for certain.
One potential option is trying an ifi silencer+ But that didn't work for me because the interference was coming from after the USB signal. You could try some kind of ground loop isolator like this 3.5mm one but I don't know how it works, I was under the impression that it required a separate connection to ground.
This entire subject is a mystery that I haven't heard of anyone solving other than myself, though my issue was pretty specific to my system.
