Extreme Performace Thermal Paste?
Care to let us know which 3 exact thermal pastes you are looking at?
My PC Specs: (expand to view)
Main Gaming Machine
CPU:  Intel Core i7-14700K
CPU Cooler: Deepcool LT720
Motherboard: MSI PRO Z790-P WIFI
Memory: G.Skill Trident Z5 RGB 32 GB (2 x 16 GB) DDR5-6400
Storage 1: Samsung 990 Pro 2 TB
Storage 2: Crucial P3 Plus 4 TB
Video Card: EVGA XC3 ULTRA GAMING GeForce RTX 3080 10GB
Power Supply: Corsair RM850 850W
Case: Corsair 7000D Airflow
Case Fan 140mm: Noctua A14 PWM 82.5 CFM 140 mm (x7)
Monitor Main: MSI G274QPF-QD 27.0" 2560 x 1440 170 Hz
Monitor Vertical: Asus VA27EHE 27.0" 1920x1080 75 Hz
<-- Moved to Cooling -->
It would really help to know the 3 pastes you can choose from.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
There's 4 in reality 😄
hope it helps
14 minutes ago, Lew123 said:
The 3 different “levels” of Corsair thermal paste. I can’t recall the names in particular
in THAT instance, it doesn't matter:  They're all pretty much fuck-off terrible.
Buy real thermal paste from Noctua, Arctic, or Thermal Grizzly.
Is there really that much of a difference? I bough the Extreme Performance Corsair stuff already. Not currently applied though.
if you already have it, i would just use it. corsair paste isn't bad, it's just more expensive than products that are better, at least in my experience. why ask after buying it?
I would just let my friend use it instead. Always looking for new, better options is all.
Thermalright TF7 is what they give away with their coolers, but it’s actually really good stuff.  I usually use SYY-157 because it’s cheap and also very good. TFX is probably my favourite.
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
in reality?  A few C.  Nothing huge.
But Arctic is 1/3 the price, and better than Corsair's "Extreme".  Hell, Noctua and Kryonaut are cheaper!  (If your product costs more than Noctua?  Ya doin something WRONG!)
Yeah lol. I’m just one of those dummies that sees the price and assumes the quality meets it..
