75 hz monitor next to 144hz
Solved by Dukesilver27-,
There's no reason your primary monitor would change, each monitor has different settings. For example, my primary monitor is 165hz and my second is 144hz, the both run at difference hz at the same time.
But, if you need to make sure, go to advanced display settings.
Featured Topics
Bonznumber1 ·
Posted in Windows0 -
aqarwaen29 ·
14
5
IBM_THINKPAD_R51 ·
Posted in Servers, NAS, and Home Lab0 -
5
1
1
