Trying to identify an AeroCool CPU cooler
44 minutes ago, JogerJ said:So I bought a pre-built with a 3300X which had this cooler on, which I eventually replaced with an AMD Wraith (I happened to have one lying around) but I have no idea what model this is. The spec sheet the builder wrote was "Standard AMD Cooler", but clearly this is not from AMD. The fan seems to be 80mm, very similar to an AeroCool Force 8, can't tell for sure because I didn't take it apart. It has 4 pin cable and clips on to the motherboard (the clips I removed to accommodate the new cooler I have installed). The heat sink is about 85mm x 85mm (3,34646 in x 3,34646 in). The heatsink doesn't resemble the shape of AeroCool BAS fans. I'm starting to wonder whether this is some frankenstein cooler the vendor made up
Anyone got ideas? Btw are the brackets that the cooler mounts to part of the cooler kit or the motherboard? I want to get rid of this fan to be recycled or something but I'm not sure if the brackets are part of the kit.
It does look more like the stock AMD cooler with an Aerocool fan strapped to it. They do have screw holes to mount a different fan so I assume that's what happened. Maybe the fan died and since it's easy to replace, just put on another fan. Maybe an AM3/AM4 cooler? I think those retention clips are the same.
