USB Drive Edges Copper!
Those are just tabs to help support the connector. That way not all of the strain goes through the data and power pins when you pull on the connector.
If you look at that PCB it does look like at least that one side is grounded through that pin. HDMI ports use the same type of pins.
R_public ·
Posted in Networking7 -
apoyusiken ·
Posted in PC Gaming0 -
4
MattJames595 ·
Posted in Troubleshooting0 -
Jimkirk363 ·
Posted in Windows3 -
Ramrod126 ·
Posted in Cases and Mods0 -
smush ·
Posted in CPUs, Motherboards, and Memory7 -
asdasdasdasdasdasd ·
Posted in Hot Deals1 -
RipperDoc5456 ·
Posted in Troubleshooting6
