I've been buying components for a ryzen 7000 build. The problem is, of course, the motherboard price: I want to wait for the "early adopt" tax to go down.
I've already bought the AIO for the CPU (EK-Vardar D-RGB 240mm) and I don't know if storing it for a long time will have negative effects.
Will pre-applied thermal paste deteriorate?
Should I put it somewhere extra dry?
Will keeping it in the box prevent most problems of long-term (a few months) storage?
please tell me if there's something I should know too.
"As long as it won't fall down a cliff, get driven over by a car or shot out of a mortar it's going to be just fine."
https://linustechtips.com/topic/1469844-aio-storage-yes-really/
i mean.. technically having it sit in the box is largely the same as having it sit in a powered down computer..
so, under your desk?
also -- assume that it's been on shelves or in transit for months before it arrived at your doorstep, having it sit in the box a while longer wont change a thing.
https://linustechtips.com/topic/1469844-aio-storage-yes-really/#findComment-15671581
Technically the box is much better at keeping the thing in good order : no dust, no heat, fans not spinning, pump off, etc ... 😄
https://linustechtips.com/topic/1469844-aio-storage-yes-really/#findComment-15671594
19 minutes ago, Senzelian said:
Just let it sit in its box somewhere safe. As long as it won't fall down a cliff, get driven over by a car or shot out of a mortar it's going to be just fine. 😉
But where is the fun in not doing that??
Desktop: AMD 9800x3d / Asus ROG Crosshair 870e Extreme / Asus ROG Astral 5090 OC / 32GB Corsair Titanium / 4TB & 2TB WD SN850x / Win 11 Pro
Plex/AI:  Intel Ultra 9 285k / Asus Tuf Gaming B860m-Plus / 2 x RTX 4000 ADA / 64GB Kingston Fury / 2 x 4TB Samsung 990 Pro / Win 11 Pro
NAS: Synology DS1821+ (8 x 20TB Seagate x24 ) / Synology RS1221+ (8 x 24TB Seagate x24) / Synology DS923+ (4 x 14TB Seagate)
https://linustechtips.com/topic/1469844-aio-storage-yes-really/#findComment-15671604
Eww pre-applied thermal paste should be a sin don't use it either way get that extra 1c with MX4. Just kidding... but I personally would replace it if it sits for more than a year
Just put it in a closet or something
Yeah but I recommend rotating the box once a month or something to slosh the fluid around.
https://linustechtips.com/topic/1469844-aio-storage-yes-really/#findComment-15671617
