Extreme Undervolting RTX 3090 bad for VRM?
1 hour ago, adm0n said:Now that I have a picture for reference, I'd say all the capacitors, the inductors labeled 2R2 (one is at the lower right of the card) and the one chip in the top right. There seem to be specific holes in the cooler, that allow air to pass to those components.
From what I found out from googling, thanks to the pictures you provided is that:
Capacitors are usually rated to operate at ~105°C for around 2000h of operation. For every 10°C they operate cooler, their lifetime doubles approximately.
Inductors don't really need to be cooled, but since they are close to the powerstage, they usually can conduct quite a bit of heat away from it, which is why they are often cooled.
So I don't need to worry about the inductors, but should I still worry about the capacitors? I would like them to last quite a bit
Running the card with that aggressive of an undervolt won't have any of the vrm components going above 60c ever, high end gpus like this will typically get 105-125c 5k-10k caps which would probably run this card for at least 20 years with occasional maintenance, I'd wager something else would die on the card first with heavy use.
