Budget (including currency): 1800 euro
Country: Lithuania
Games, programs or workloads that it will be used for: War game such as battlefield, war thunder, cod. And racing games like nfs and forza 5.
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I aim to play at 1440p. My build is here https://pcpartpicker.com/list/mrKwZw the case is genesis irid 505 argb. It looks over budget but in my country its not. I just want to check if everything will fit if it all has the conectors i need. The thing that worrys me if the cpu cooler will fit in the case. I looked it up the clearence is 8mm is this enough?? Do i need another fan for the exaust?  Will the gpu sag? Will there be any other issues that i dont know of?
https://linustechtips.com/topic/1468989-im-a-new-builder-need-help/
3 minutes ago, jaslion said:
How much is a 12600k? It shouldnt be too much more but the extra cores will increase its longevity by a lot.
Its 312 euro and the 12400f is only 180. In the future i plan to upgrade into 13th gen cpu like the 13600k or the 13600kf
I agree a faster CPU would be good. A 7600X is listed on pcpartpicker for the same price. @Du2kasAlso have you considered waiting for a 7900 xt?
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
No i havent but if its around the same price i might as well wait for it. And the 7600x costs around 300 so still over budget.
Its 899 euro msrp, so should be around the same
Gaming PC:
Linux PC:
See the 6900xt msrp was 680 and look how high it is now after a long time it still hasnt even been close to the msrp. So if the 7900xt msrp will be 899 i bet it will soon become something like 1200
1 hour ago, Du2kas said:
What about other questions i asked??? Can you answer them?
Yes. Case has 4 fans already so should be fine, CPU cooler will fit, because it's under the 165mm limit of the case. GPU will sag because its big and long, but it dosen't matter actually (all gpus sag). You can get mounts if you worry.
Gaming PC:
Linux PC:
Will adding the extra fan boost temperatures? So is this a good build??
Not really. The fan config is very decent in that case. Use the money on better cpu and board
Gaming PC:
Linux PC:
5 minutes ago, Du2kas said:
OK. And another question which case would be better the genesis irid 505 argb or the BitFenix Nova Mesh SE TG ARGB
I would get the genesis, just because it has a little more clearance and looks better imo, both should perform similar. Looks like a very decent case for the price!
Gaming PC:
Linux PC:
