Can an AIO CPU liquid cooler be mounted vertically with rad I/O on the top?
Solved by Shimejii,
Im going to be straight up honest with you, Buying "cheap" Liquid coolers is probably one of the dumbest things you can do. You are putting your system at so much of a risk for cheap liquid coolers like that, especially when that ML line hasnt had a stellar reputation. Just buy a Scythe cooler for that price and be fine
To answer your question with tubing placement, It generally doesnt matter until a few years down the road, Tubes down tend to make less noise and cause less issues due to the fluid levels and such, pump location inside the radiator doesnt resolve it THAT much, since that tends to be important to take that into account as well. It just moves the point of where you have to worry about the liquid levels.
