help with cooling recommendations
I mean in general 70C is fine.
But if you want it to run cooler you could go with any number of coolers such as a noctua. But we would need to know your case to better advise
If someone has helped you out on the forum don't forget to give them a reaction to say thank you!
The only true wisdom is in knowing you know nothing. - Socrates
Please put as much effort into your question as you expect me to put into answering it.
1 hour ago, sixgodcode said:
Im running a Ryzen 7 5700x with an SilverStone KR03 92mm as cooler, and its getting 70 celsius when im playing
That should be a fine temps for most load thrown at it and then some if you dont mind going louder. +1 on @GOTSpectrumthough, we gonna need more info such as case model, budget, RAM model, and your motherboard model too.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
Welcome to the LTT forums! First a disclaimer 70 C is a perfectly safe temp that will allow for a very long life of the system (there are people who run their systems much hotter), but first a case form factor would be most helpful in certifying the fit of a cooler recommendation, otherwise with just a blind shot in the dark assuming a mid size tower ATX case or larger a Be Quiet! Pure Rock 2 would be a good option.
In search of the future, new tech, and exploring the universe! All under the cover of anonymity!
(im from brazil sorry if my english sucks)
any budget coolers(aio or air)?
(i would love playing with 60 celsius)
Seeing 60C when gaming is a nice thing for sure, but 70C is just fine. It's literally just money out of the window, sort of, you're not "fixing" anything. But I still get it though, nice numbers are, well, nice numbers 😛
GAMER
SPEC: HYTE Y60 White/Black + Custom ColdZero ventilation sidepanel – AMD Ryzen 7 9800X3D + ASUS ROG RYUJIN III 360 – G.SKILL Trident Z5 Neo RGB DDR5-6000 64GB CL30-40-40-96 – ASUS RTX ROG ASTRAL 5080 OC – ASUS ROG STRIX B850-E GAMING Wi-Fi – Samsung EVO Plus 1TB, Samsung EVO Plus 1TB – Corsair HX1200i
GEAR: Samsung Odyssey Neo G9 G95NC 57" – ASUS ROG Harpe Ace Aim Lab Edition Wireless – ASUS ROG Claymore II Wireless –
ASUS ROG Sheath BLK LTD – FiiO K7 DAC/AMP + Beyerdynamic DT 770 PRO X (Limited Editon), Edifier S351DB, Steelseries Arctis Nova Pro Wireless
Home LAB
SPEC: Corsair 4000D Airflow TG – AMD Ryzen Threadripper 1950X – Corsair Vengeance LPX 128GB (CMK32GX4M2D3000C16 x4) – ASUS GeForce GT710 1GB – ASUS ROG Zenith Extreme – ROG AREION 10Gbps – Toshiba XG6 1TB, WD 256GB, Kioxia 256GB – Corsair HX750
GEAR: Philips 346B1C 34" – Logitech MX Keys – Logitech M705 – Jabra Evolve2 75
Racing SIM
GEAR: Sim-Lab GT1 EVO Sim Racing Cockpit + Integrated Vario Triple mount – Svive Racing D1 Seat – MSI 325CQRXF 32" x3 – Simagic Alpha Mini + Simagic GT4 (Dual Clutch) – CSL Elite Pedals V2 – Logitech K400 Plus
If you still want a good cooler for that CPU Thermalright PA120 is a good choice.
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
