Well...Let Me Tell You Something,I Have A Tablet. my uncle got it from a friend and he gave it to me. And MAN... Pain.
1 GB of ram.
8 GB of memory.
And my god. every time that I played Anything,it started to get hot. REALLY HOT.
I put it to charge and it got soo hot. IT BURNED THE CHARGER.
I'm never using the tablet again
https://linustechtips.com/topic/1466494-i-need-help/
1 GB of ram.
8 GB of memory.
What exactly do you need help with?
A new tablet to play games on? A way to cool the tablet you have? How to stop your house from burning down?
https://linustechtips.com/topic/1466494-i-need-help/#findComment-15647456
  • 2 weeks later...
On 11/12/2022 at 3:57 PM, BrazilianFriend said:
Thank god someone,i am here to ask,is it possible to put a better OS? or Root?
Depends on the model. You might install something like LineageOS, but the compatibility list indicates support for only a few tablets.
As it stands, a new OS or rooting won't necessarily make it run faster or at lower temperatures. Your problems could be tied to the inherent hardware design, and that might well be the case given that even charging the tablet leads to overheating.
https://linustechtips.com/topic/1466494-i-need-help/#findComment-15666202
