So I built the computer from Linus latest rgb build a few months ago and have been running into constant problems and have tried every solution I could find on the internet. The first problem I had was with a blue screen with clock watchdog timeout and one other blue screen but mainly the first one I disabled turbo boost in bios which fixed it. I think the error might have been due to extreme sudden spikes of heat  because the new problem I’m having is the cpu overheating even just idling or in bios I tried cleaning off and putting new thermal paste on and making sure the cooler was properly mounted check in bios that all the fans and the pump were spinning the over heating has only gotten worse I think cause I use to be able to at least use the computer but now I can’t even use it without it overheating in minutes the only thing I can think is something with the water pump cause makes a loud clicking on startup then goes away I thought maybe a air bubble so tried moving it while running to try to get air bubble to move from pump cause read online that might be the issue but no luck
https://linustechtips.com/topic/1466368-multiple-computer-errors-and-problems/
@SpookyCitrus I saw you in cooling diagnosing temp issues.
current PC:
PC configs I used before:
Can you please list your full specs, and link the video of the build you are referring to please? Without a full spec list of exactly what you have we cannot help you properly.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
motherboard asus Maximus hero xiii
cpu 11900k
Water cooler mag core liquid 360r
4x8 trident z 3200 ram
1200w Thor asus psu
nividia strix 3080
all the drivers should be up to date also
And the only think I did differently from the video was instead of a 10850k I used 11900k and instead of and graphics went with nividia
