How much power does an ATX motherboard send to the power LED?
I'm wanting to know how much power is sent to the Power LED on the front of ATX cases.
I want to control the power LED on my case with an Arduino, but I'm not sure how much power is sent to those LEDs.
Is it 3.3V and the power LED board adds a resistor or do I need to add a resistor on the way out?
Full Story
I'm building my own SAS Expander box. This is a system with a single SAS Expander card, PSU, and a bunch of drives. No motherboard.
To control powering the case, I'm going to use an ESP8266. It's similar to an Arduino and even works if I flash it with C code from the Arduino IDE.
The 24-pin ATX connector provides 5V when in standby; the exact kind of power that devices like the ESP8266 use.
With a relay and some code, I've already set it up so the ESP8266 can power on and off the PSU, but I'm missing the LED.
Since I know the state of the PSU (as I'm controlling the relay), I can also output power to the LED like a regular motherboard. But doing so requires knowing how much power I need to send the case's power LED.
The power LED output on a motherboard is controlled by either the chipset or the superIO chip (I haven't narrowed down which) through discrete transistors (I've dug around a little bit).
If all you want is a power indication, use a dropping resistor to match the spec of the LED you choose from whichever rail is the most convenient.
Main System (Byarlant): Ryzen 7 5800X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 16GB G.Skill DDR4 3200MT/s CAS-14 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 960 PRO 512GB / 4× Crucial MX500 2TB (RAID-0) | Corsair RM750X | Mellanox ConnectX-3 10G NIC | Inateck USB 3.0 Card | Hyte Y60 Case | Dell U3415W Monitor | Keychron K4 Brown (white backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB RAM (soldered) | Vega 6 Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi (all-around awesome machine)
Proxmox Server (Veda): Ryzen 7 3800XT | AsRock Rack X470D4U | Corsair H80i v2 | 64GB Micron DDR4 ECC 3200MT/s | 4x 10TB WD Whites / 4x 14TB Seagate Exos / 2× Samsung PM963a 960GB SSD | Seasonic Prime Fanless 500W | Intel X540-T2 10G NIC | LSI 9207-8i HBA | Fractal Design Node 804 Case (side panels swapped to show off drives) | VMs: TrueNAS Scale; Ubuntu Server (PiHole/PiVPN/NGINX?); Windows 10 Pro; Ubuntu Server (Apache/MySQL)
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s CAS-22 | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / Seagate 1.5TB HDD | Corsair CX450M | Viewcast Osprey 260e Video Capture | Mellanox ConnectX-2 10G NIC | LG UH12NS30 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Camera: Sony ɑ7II w/ Meike Grip | Sony SEL24240 | Samyang 35mm ƒ/2.8 | Sony SEL50F18F | Sony SEL2870 (kit lens) | PNY Elite Perfomance 512GB SDXC card
Network:
                           ┌─────────────── Office/Rack ────────────────────────────────────────────────────────────────────────────┐
Google Fiber Webpass ────── UniFi Security Gateway ─── UniFi Switch 8-60W ─┬─ UniFi Switch Flex XG ═╦═ Veda (Proxmox Virtual Switch)
(500Mbps↑/500Mbps↓)                             UniFi CloudKey Gen2 (PoE) ─┴─ Veda (IPMI)           ╠═ Veda-NAS (HW Passthrough NIC)
╔═══════════════════════════════════════════════════════════════════════════════════════════════════╩═ Narrative (Asus USB 2.5G NIC)
║ ┌────── Closet ──────┐   ┌─────────────── Bedroom ──────────────────────────────────────────────────────┐
╚═ UniFi Switch Flex XG ═╤═ UniFi Switch Flex XG ═╦═ Byarlant
   (PoE)                 │                        ╠═ Narrative (Cable Matters USB-PD 2.5G Ethernet Dongle)
                         │                        ╚═ Jesta Cannon*
                         │ ┌─────────────── Media Center ──────────────────────────────────┐
Notes:                   └─ UniFi Switch 8 ─────────┬─ UniFi Access Point nanoHD (PoE)
═══ is Multi-Gigabit                                ├─ Sony Playstation 4
─── is Gigabit                                      ├─ Pioneer VSX-S520
* = cable passed to Bedroom from Media Center       ├─ Sony XR65A80K (Google TV)
** = cable passed from Media Center to Bedroom      └─ Work Laptop** (Startech USB-PD Dock)
Retired/Other:
Laptop (Rozen-Zulu): Sony VAIO VPCF13WFX | Core i7-740QM | 8GB Patriot DDR3 | GT 425M | Samsung 850EVO 250GB SSD | Blu-ray Drive | Intel 7260 Wifi (lived a good life, retired with honor)
Testbed/Old Desktop (Kshatriya): Xeon X5470 @ 4.0GHz | ZALMAN CNPS9500 | Gigabyte EP45-UD3L | 8GB Nanya DDR2 400MHz | XFX HD6870 DD | OCZ Vertex 3 Max-IOPS 120GB | Corsair CX430M | HooToo USB 3.0 PCIe Card | Osprey 230 Video Capture | NZXT H230 Case
TrueNAS Server (La Vie en Rose): Xeon E3-1241v3 | Supermicro X10SLL-F | Corsair H60 | 32GB Micron DDR3L ECC 1600MHz | 1x Kingston 16GB SSD / Crucial MX500 500GB
why,
power the led directly from the psu using a resistor of correct size.
if the psu is on (not in standby 5v) the led is on. simple as
11 hours ago, OhYou_ said:
why,
That's a much better idea! 👍
I already bought one of these 24-pin breakout boards which'll make it easier:
Source: https://www.amazon.com/gp/product/B01NBU2C64/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
I'll take +3V3 & COM (ground) to get the light setup, but I'm not sure which resistor to use. I have a few from a Raspberry Pi kit years ago, just dunno which one to look for or how to read them.
Looks like blue LEDs typically need 3.0-3.5V, but there's no way for the motherboard to know that, so it must be fine with 2.2V right? I'm really wondering if the board itself takes 3.3V and has the resistor already on it.
Here are some possible resistor values based on the LED voltage:
2.2V LED
3.3V LED
Source: https://ledcalculator.net/#p=3.3&v=3.3&c=20&n=1&o=w
Another way is to measure the power LED pins on my board, but I don't really have the tools for that.
2.2V LED
3.3V LED
The values of the resistor don't need to be exact. They have a fair amount of leeway. Use a led calculator and most decent ones will give you a recommendation based on the color of the led.
