a single USB C charging port hub solution ?
Solved by m9x3mos,
1 hour ago, FCHPRO said:thanks for this reply.
The SSD i have is fast and i would like to get full performance by using a USB C port
quick question : If i find a way to buy a 2-1 USB C splitter would it work for charging and data transfer ? (i see a lot of these USB C splitters have "Audio" and headphones icons on one of usbc ports so i'm wondering is it only for charging and audio or could it handle charging and heavy data transfer ?
You would want something more like the below linked product. A standard hub won't support power delivery which you will need for charging the laptop.
