I thought that some people might like some build recommendations for some varying prices So i have a few builds, varying in prices.
All prices are Canadian $.
500$ htpc Build
 Good for upgrading and to playback video in the living room
http://ca.pcpartpicker.com/p/3PdHp
$600 Apu Build
For small form-factor builders, and general use while still packing a punch. Also good for upgrading.
http://ca.pcpartpicker.com/p/3BoGJ
$800 Build
Good For entry-level gaming and school work.
http://ca.pcpartpicker.com/p/3Bp72
$1000 Build
Built for single 1080p monitor gaming.
http://ca.pcpartpicker.com/p/3BlVB
Also a Small Form Factor
A combo of the builds above and below
http://ca.pcpartpicker.com/p/3CRxM
Small Form Factor
Great for in the dorm or in a small bedroom
http://ca.pcpartpicker.com/p/3BLBy
$1250 "Sweat-Spot" build
good for overkill 1080p gaming and recording
http://ca.pcpartpicker.com/p/3BGqC
$1500 Build
Built for gaming on 1 1440p or 3 1080p Monitors.
http://pcpartpicker.com/p/3BiUB
Team Green
From the men in green
http://ca.pcpartpicker.com/p/3BUVT
Team Red
Everything* AMD
http://ca.pcpartpicker.com/p/3BUDZ
$2000 Build
Overkill for anything.
http://ca.pcpartpicker.com/p/3BiHH
Do you Even 4k
Ready for 4k gaming, liquid cooled
http://ca.pcpartpicker.com/p/3BUjV
Peripherals
(good on budgets)
Corsair K70 (if you can find it)
Razer DeathAdder
Beyerdynamic Dt770
Blue snowball
All together About $500
If you have any suggestions for the builds or builds you think should be here leave them in the thread.
My Rig
PCPartPicker part list: http://ca.pcpartpicker.com/p/kGNksY
CPU: Intel Core i7-4770 3.4GHz Quad-Core Processor  ($379.00 @ shopRBC)
CPU Cooler: RAIJINTEK THEMIS 65.7 CFM Sleeve Bearing CPU Cooler  ($34.99 @ NCIX)
Motherboard: MSI CSM-H87M-G43 Micro ATX LGA1150 Motherboard  ($78.83 @ DirectCanada)
Memory: Kingston HyperX 16GB (4 x 4GB) DDR3-1600 Memory  ($139.99 @ Memory Express)
Storage: Kingston Fury 120GB 2.5" Solid State Drive  ($71.34 @ DirectCanada)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($92.95 @ Vuugo)
Video Card: Gigabyte Radeon R9 280X 3GB Video Card  ($298.98 @ Newegg Canada)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case  ($125.98 @ Newegg Canada)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($66.99 @ NCIX)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($116.00 @ shopRBC)
Case Fan: Cougar Turbine 120 (4-Pack) 60.4 CFM 120mm  Fans  ($23.99 @ NCIX)
Monitor: HP 22xi 60Hz 21.5" Monitor  ($187.11 @ Amazon Canada)
Keyboard: Logitech G710 Wired Gaming Keyboard  ($114.99 @ NCIX)
Mouse: Razer DeathAdder 2013 Wired Optical Mouse  ($76.99 @ Amazon Canada)
Headphones: Kingston HyperX Cloud Pro Headset  ($78.98 @ DirectCanada)
Total: $2074.22
Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2015-04-10 15:33 EDT-0400Build log http://linustechtips.com/main/topic/303263-the-dell-from-hell/#entry4121100
Phone Compassion Spreadsheet https://docs.google.com/spreadsheets/d/1EN6s426gyxqPloIqT4wQ7Y7yovkkQy_5B3djVN-N-R8/edit#gid=0
Gta V Pc Online Crew http://linustechtips.com/main/topic/344773-unofficial-linus-tech-tips-gta-v-crew-pc/
https://linustechtips.com/topic/146335-many-build-for-many-needs/
Maybe the person who can't afford a lot, you should add $400, $500 and $800 builds. I like the ones above, they're pretty balanced
yeah i was planing on doing thises later today i have to go to school
My Rig
Total: $2074.22
EDIT: on the $1000, there is a k series CPU but you can't OC on that motherboard.
Yeah that would be cool
The time you enjoy wasting, is not wasted time.
I just skimed on the mobo i will change after school and do some cool builds like "for the audiophile" or "the renderer"
Motherboards are a area i want to learn more about and currently dont know much about them
My Rig
Total: $2074.22
Do one for the us buyers too
One point when choosing mobo for k unlocked cpus. You need to pair with any Z87 boards. Use other series board for non OC Intel chips.
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
Srry acidential post
My Rig
Total: $2074.22
I updated the 1k build and sicne its is cad you can upgrade items cause the items cost less in us
My Rig
Total: $2074.22
$1000 - pc
v300 ssd could be improved considering the recent depreciation in performance,
otherwise i like what i see
Cheapest 120gb ssd i could find
My Rig
Total: $2074.22
added some new build and i would love feedback on them
My Rig
Total: $2074.22
I like them, very well balanced.
that is my point in these, good for gaming, and other uses aswell while mainly being gaming, i particularly like my use of a sshd, something that isnt used much these days
My Rig
Total: $2074.22
Team red is terribly balanced
it is meant to be all amd, feel fee to change things if you build these rigs
My Rig
Total: $2074.22
  • 2 months later...
My build should be named "Do you even 4K Surround, bro?"
ACS Systems - Jason Neal
My "Danger Den" PC: i7-4960x @ 4.5Ghz, ASUS X79 Deluxe, 3x GTX Titan Black, 6x m4 512GB, 64GB Corsair DDR3-2400, Corsair AX1500i
Black Beauty Workstation/LAN PC: i5-4570 @ 3.79 GHz, ASRock Z87E-ITX, XFX Double D R9-280 (Non-X), GSkill 8GB DDR3-2400
no, not enough titan blacks
My Rig
Total: $2074.22
  • 1 month later...
Lol sweat spot. Rename it to '"Armpit" build'
these are old man, and using cad, i was not as good at it then as i am now
My Rig
Total: $2074.22
