Getting memory errors while running 4 sticks of Corsair Vengeance RGB Pro 8GB (3200MHz), but ONLY when XMP is enabled.
Solved by 191x7,
The Zen+ memory controller can't handle 3200 MT/s on 4 slots, it's even a feat having 3200 stable on 2 slots with it. It's rated for 2933 at 2 slots and there's no quarantee to have even 2933 on 4 slots. It is not an opinion, it's a hardware fact.
And yes, as it was already stated, it's not a motherboard issue since the memory controller is on the CPU, so using the old motherboard but upgrading the CPU to a Zen 2 or Zen 3 will probably result with running 3200 on 4 slots without issues since their memory controller officially supports 3600.
Also, XMP is overclocking.
