So i've been using some Krylon paint and it chipped really bad. I figured it would adhere because the brackets had a rough surface to them and the front and back sides of the bracket are fine however on the sides i think it was a little smoother and its just coming right off. Should i clear coat or should i sand down the areas that are chipping and try again?
post-11646-0-89530500-1398829252_thumb.j
Work Desktop | CPU: Intel Core i7 4770k | GPU: Quadro K1200 | Motherboard: EVGA Z97 Classified | RAM: Corsair Dominator Platinum 32GB (4x8GB) DDR3-2133Mhz | PSU: Seasonic 750W SS-750KM3 80 PLUS Gold | STORAGE: WD 1TB Se Enterprise Grade Drive & Corsair Neutron NX500 400GB NVMe PCIe  | COOLER: Enermax Liqtech 240 -  5x Noctua NF-F12 iPPC 2000 PWM | CASE: Corsair 600C | OS: Windows 10 Pro | Peripherals: Logitech MX Master 2S -- Logitech K840 -- INTEL X520 10Gb NIC -- 3x Acer H236HL -- Build Log |
Work Server | CPU: Intel Xeon E5-2650 v3 | Model: Cisco UCS C220 M4 (SFF) | RAM: 64GB (4x16GB) Cisco (Samsung) DDR4 2133Mhz | STORAGE: 4x Cisco (Seagate) 900GB 10K 2.5" (RAID 10) - 2x 32GB Cisco FlexFlash Boot Drive (RAID 1) | OS: vSphere 6.7 Enterprise Plus U3 |
Laptop | CPU: Intel Core i7 6700HQ | GPU: Nvidia GTX 960M 2GB GDDR5 | RAM: 32GB (2 x 16GB) DDR4-2400Mhz | STORAGE: 512GB Hynix NVMe | OS: Windows 10 Pro |
Gaming Desktop | CPU: Intel Core i7 9700K | GPU: Gigabyte RTX 2080 WINDFORCE 8G  | Motherboard: ASRock Z390 PHANTOM GAMING-ITX | RAM: Ballistix Elite 32GB Kit (16GB x 2) DDR4-3000 | PSU: Silverstone SX700-LPT 700w 80 PLUS Platinum | STORAGE: 2x Samsung 970 PRO 1TB NVMe | COOLER: Noctua NH-L12 | CASE: Louqe Ghost S1 | OS: Windows 10 Pro | Build Log in Progress |
Home Server | CPU: Intel Xeon E5-2690 (Sandy Bridge) | GPU: Quadro P2000 | Motherboard: SUPERMICRO X9SRL-F  | RAM: 64GB (8x8GB) Micron VLP DDR3-1600 ECC | PSU: SUPERMICRO 665W 80 PLUS Bronze | STORAGE: 2x Samsung 860 EVO 500GB (RAID 1) - 4x WD 8TB Ultrastar (RAID 10) - Intel SSD D3-S4510 Series 240GB (BOOT)  | COOLER: Noctua NH-U12DXi4 with 2x Noctua NF-F12 iPPC 3000 PWM | CASE: SUPERMICRO CSE-842TQ-665B 4U | OS: vSphere 6.7 Enterprise Plus U3 | Build Log in Progress |
| Pixel 4XL 128GB - Clearly White - Unlocked - Carrier: Visible |
| F@H STATS |
https://linustechtips.com/topic/146197-paint-for-pci-brackets/
I used Krylon Fusion for plastic. It was a glossy paint. I haven't had any issues with chipping. Are you painting black brackets with white paint? You'll need a lot of coats.I would just sand and try again. It couldn't hurt to clear coat after you've reapplied the paint though.
https://linustechtips.com/topic/146197-paint-for-pci-brackets/#findComment-1952300
Sanding it down should help, but you could start by using paint meant for plastics.
How would that help?
| F@H STATS |
https://linustechtips.com/topic/146197-paint-for-pci-brackets/#findComment-1952317
Sanding or paint meant for plastics?
Usually paint sticks better to rougher surfaces so it doesn't just drip off.
Paint meant for plastics... kinda obvious why..
Yeah but the brackets are metal
| F@H STATS |
https://linustechtips.com/topic/146197-paint-for-pci-brackets/#findComment-1952328
Wow I was thinking of the wrong thing. (I'm sick, leave me be :P)
Just sand them a bit.
fine or rough sand paper
| F@H STATS |
https://linustechtips.com/topic/146197-paint-for-pci-brackets/#findComment-1952342
PCI brackets tend to have fairly tight fits depending on the design so thin coats are better, try using an extremely durable finish paint such as engine enamels or ceramics. Best thing to do is take steel wool or 220 grit sand paper and sand down parts, personally I like to lightly prime the parts before painting with topcoat to ensure adhesion.
https://linustechtips.com/topic/146197-paint-for-pci-brackets/#findComment-1952417
Did you follow the directions on the can? Not meeting temperature and humidity levels can really mess up how durable paint is. Did you also wait 24 hours before messing with it? Dry paint is not cured paint.
Paint sticks to other paint very well, so I personally wouldn't bother using primer, it is more-so meant for bare metal. Lightly sanding it with 200 or higher grit sand paper to rough it up a bit will help.
Generally speaking, the longer time the directions say it takes to dry the more durable the paint will be. If you want a gloss finish, use appliance paint. It is probably the most durable paint you will find at a local hardware store, but IIRC the cure time is several days.
https://linustechtips.com/topic/146197-paint-for-pci-brackets/#findComment-1956734
If you want to keep using krylon, then yes you should clear coat it for sure,  but I would look into using their high heat engine paint. That stuff is intense. However I would look into using Plastidip. I haven't used it myself, but I've heard good things about it.
People use it for cars all the time, and you can peal it off because it is like a spray on wrap.
https://www.google.com/search?q=plasti+dip&es_sm=122&source=lnms&tbm=isch&sa=X&ei=kHJgU6H2LuSMyAHzroCYBA&ved=0CAoQ_AUoAw&biw=1920&bih=955
I agree with the PlastiDip idea.  I just bought some myself for my rig and I can't wait to get started on mine.  The best part is that if you don't like it, you can always peel it off and start over.
"The doctors X-rayed my head and found nothing."  - Dizzy Dean
i7-4770K, ASUS Z87 Gryphon, EVGA GTX 780 Ti, 16 GB Kingston Fury RAM, Crucial M500 240 GB, 1TB Seagate Barracuda, Cooler Master Hyper 212 Evo, Seasonic 760W PSU, Asus BD, Phanteks Evlolv mATX (Gunmetal).
https://linustechtips.com/topic/146197-paint-for-pci-brackets/#findComment-1968446
