RTX 2080 Metal Grinding Noise at load! HELP
Solved by merco,
3 hours ago, Helpneeded999 said:Damn, yeah it does actually sounds like that... So because i cleaned the PC and got all the dust out of the case, now it has coil whine... I should have kept it dusty haha... That sucks... I'll try to open up the card and see if i can do anything also change the thermal paste..
not sure if it has been mentioned before but I was looking at videos about coil whine and they suggest to try undervolting your card and also cap your FPS or even turn on gsync/freesync because it's worse at high FPS.
