Micro atx 280mm aio
Solved by dizmo,
There's a chance it won't. IIRC AMD is making an adapter kit so that coolers will work. If the mount makes use of AMDs backplate you're fine, otherwise you're not.
6
popularlion ·
Posted in Troubleshooting4 -
2
CallMe_David ·
FancyPants101 ·
Posted in Troubleshooting1 -
BoBo6107 ·
R_public ·
Posted in Networking16 -
apoyusiken ·
Posted in PC Gaming11
