Plese help JAVA Bolean not working
Solved by Eigenvektor,
That code seems pretty complicated for what you're asked to do. How about using AND (&&) and OR (||), rather than XOR?
final boolean isCold = input.nextBoolean(); final boolean isDry = input.nextBoolean(); // For less mind-fuckery final boolean isHot = !isCold; if (isHot) { System.out.print("It is hot\n"); } if (isDry) { System.out.print("It is dry\n"); } if (isHot || isDry) { System.out.print("It is hot or dry\n"); } if (isHot && isDry) { System.out.print("It is hot and dry\n"); }
