Bent USB 3.0 pin, worth fixing?
Solved by SlashedM,
10 minutes ago, AltF4_345 said:One of my usb 3.0 headers has a bent pin. The pin is close to another one and being the paranoid that I am, I worry about the pin being close to the other one. Will it cause problems? It isn’t touching the other one, and I don’t want to go though the hassle of removing the gpu and its brace and the front fans just to straighten it out.
If youre not using the port, should be fine.
Featured Topics
Emmanuel Katto ·
Posted in Peripherals3 -
1
2
Rusty Proto ·
4
WildOne ·
Posted in New Builds and Planning1 -
solarbear ·
Posted in Troubleshooting1 -
4
2
play_circle_filled
Latest From ShortCircuit:
Lian-Li, do this on all of your cases! - Lian-Li O11D x Lamborghini
