Best aio for cooling the 12900k?
Solved by Alex Atkin UK,
6 minutes ago, Ryuikko said:I guarantee you that a 12600k won't bottleneck a 4090, but if you're looking for as much future proof as you can get, then get am5. Should have more than enough upgradibility since it should be upgraded for more than 5 years or so
Agreed, from the reviews I've seen so far the top-end AMD and Intel are a huge waste of money for gaming.
I got a 5950X earlier in the year for a similar reason. I only went that high knowing I may sometimes use it for things where more cores is useful, and it leaves me with tons of flexibility later on what I can use it for when I eventually replace it. If its just for gaming, higher clocked, less cores is better value.
