Heya. I'm a complete newb when it comes to PC building and I'm just about to build my first one. However, I came upon an issue.
I have a total of 10 case fans + CPU fan (so 11 total), but nowhere to actually plug them.
My motherboard doesn't have space and I read up it's better to connect to PSU through a fan hub.
Problem is, I don't own a fan hub yet, and every fan hub I seem to find online, is not sufficient enough to support a whole 11 fans.
Something that also worries me is, whether the fan hub can actually power all my 11 fans if I manage to find one with enough slots. Also, I imagine it will be a wiring nightmare when I have case fans set on all 4 cardinal directions.
Top fans, bottom fans, side fans on both sides, and the CPU fan will be somewhere in the middle of the mess.
Help 😵💫
https://linustechtips.com/topic/1456902-looking-for-fan-hub/
I would exclude the CPU fan anyway from the fanhub and connect that directly the the motherboard CPU_FAN header, since then it will be speed controlled depending on temprature.
Then all the others can be on the fanhub.
When i ask for more specs, don't expect me to know the answer!
I'm just helping YOU to help YOURSELF!
(The more info you give the easier it is for others to help you out!)
Not willing to capitulate to the ignorance of the masses!
https://linustechtips.com/topic/1456902-looking-for-fan-hub/#findComment-15577114
Thanks for the tip. I assume if my fan hub has a "CPU fan" slot unused, I shouldn't connect a normal case fan on it?
https://linustechtips.com/topic/1456902-looking-for-fan-hub/#findComment-15577123
All boards have a CPU fan header slot and at least a couple ones in addition (SYS1 2 etc)0
You need to also get a pair of splitters (unless you have daisy chainable fans) so you put 2-3 fans on 1 "final" header (group the ones on the same side that should run same speed), then you plug the "final" headers on any 6 headers hub
https://linustechtips.com/topic/1456902-looking-for-fan-hub/#findComment-15577128
Get two 6 or 8 port fan hubs which are sata powered and then just use a 2 port 4 pin splitter to the hub from a single fan header
Or skip the splitter and plug the fan hubs into two sys ports on the board and set them to be the same fan curve in bios.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/1456902-looking-for-fan-hub/#findComment-15577180
Putting all fans on the motherboard is a bad idea from my understanding since it's going to overload the motherboard.
https://linustechtips.com/topic/1456902-looking-for-fan-hub/#findComment-15577449
They are SATA powered 🙂
Edit:
The bigger 6+ port hubs are all powered by SATA and only the PWM signal comes over the motherboard header to the fans allow you to control them all at once off a single hub.
Prior Build Log/PC:
https://linustechtips.com/topic/1456902-looking-for-fan-hub/#findComment-15577691
