Booting/Driver Installation without iGPU?
16 minutes ago, Gessler555 said:Are you required to have a GPU installed to get ANY kind of display output? Even the BIOS & Desktop?
Just one. With modern boards, it's only either the iGPU (integrated) or the dGPU (discrete). Even for the BIOS and the desktop.
16 minutes ago, Gessler555 said:How do you install the drivers for the GPU if you want to do a clean install if the display won't show anything?
The GPU will display 2D no matter what. If you're worried that there are no drivers, Windows installs basic drivers that are compatible with pretty much any GPU just so it's more stable in the desktop for the time being. Then you can go on and find the drivers online.
There really isn't much to worry about. Only problem you might run into is that the dGPU dies and you can't use the computer at all.
To avoid this, I personally would recommend picking the standard non-F version so that whenever you run into an issue, you can disconnect the dGPU and make use of the iGPU to troubleshoot (after a cmos reset if you're unable to access the bios). When you're using the PC normally, you can have the iGPU disabled in the bios (although I think it might disable/enable automatically with a modern BIOS, you'll have to figure this out yourself).
