Gpu stuck need help!!
Go to solution Solved by AnonymousGuy,
2 minutes ago, Bob_The_Coalminer said:
When i tried to remove my gpu i heard some cracking noises.(And yes i did remove the screws in IO bracket)
if it's in there really stiff then it could flex the motherboard which makes noises.  But yeah probably just give it a heave-ho since there's no other way it can be "locked" in.
If that tab broke off, there isn't anything preventing the GPU from coming out. It should just come out assuming there isn't anything else preventing its removal (a screw, the ton of dust stuck in the PCIe slot gumming it up, etc.).
https://linustechtips.com/topic/1452920-gpu-stuck-need-help/#findComment-15549041
5 minutes ago, Bianks84 said:
At first I thought you said A ton but I was mistaken 😅
OP please get some compressed air to clean that slot out before putting anything back in there.
Can’t get my hands on compressed air at this time, the gpu won’t move at all,the reason why i’m trying to remove it is because of the dust 😅
https://linustechtips.com/topic/1452920-gpu-stuck-need-help/#findComment-15549051
Ooof.
Well a clean and unused paint brush can help to dislodge dust as well.
Did you get all the screws near the rear of the card on the I/O bracket?
https://linustechtips.com/topic/1452920-gpu-stuck-need-help/#findComment-15549054
You made sure you removed the screws holding the graphics card in?? Make sure you don't have any display cabled plugged in as well.
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
https://linustechtips.com/topic/1452920-gpu-stuck-need-help/#findComment-15549073
The slot latch catches on the little U shaped notch on the PCB.  So you should be able to wiggle the card out as-is right now.  Make sure the screws are out of the bracket, no video cables plugged in.
Sometimes the motherboard is a little bit offset in the case or the IO bracket is bent and gets caught.  Hence: wiggle and it should come free.
Workstation:  9800X3D|| Asus X670E ProArt Creator || MSI Gaming Trio 4090 Shunt || T.Force 7800CL34 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ P-Core only || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 4070 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
https://linustechtips.com/topic/1452920-gpu-stuck-need-help/#findComment-15549074
https://linustechtips.com/topic/1452920-gpu-stuck-need-help/#findComment-15549113
https://linustechtips.com/topic/1452920-gpu-stuck-need-help/#findComment-15549122
