8 minutes ago, alexfer84 said:
I want to see how my custum pc build will looks after i buy it i dont know photo shop so i was hoping there was a website is so please share
You mean before right? Modelling it after you buy everything defeats the purpose.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/1452168-pc-3d-model/#findComment-15543246
7 hours ago, alexfer84 said:
Yeah is their a way?
I don't know of any sites that have 3D models for you to pretend-build a case with, so unless you're a 3D artist you'll just have to use your imagination.
You know what case you bought, and that's 90% of the appearance. You can always do an image search for other peoples' builds in the same case.
(Disclaimer: I'm a curmudgeon who thinks the PC should be a box that sits on the floor. Money spent on pretty lights is money not spent on performance.)
https://linustechtips.com/topic/1452168-pc-3d-model/#findComment-15545098
List of Components in the current version
https://onedrive.live.com/view.aspx?resid=11F4002E1134F403!666071&ithint=file%2cxlsx&authkey=!AFkjSXnXIbRL2e0
https://pcbuildingsim.fandom.com/wiki/All_Components
Refresh before you reply
https://linustechtips.com/topic/1452168-pc-3d-model/#findComment-15545160
Even if some companies provide 3D models of their hardware the odds of being able to get proper accurate 3D models for all your specific components is basically zero and I wouldn't even bother.
PC Building Simulator partnered with some brands to include models of real hardware in the game, but it still likely won't have all of the components you use and it probably isn't the most accurate.
The case is going to matter most for how the PC looks, so have a look at the photos on the case website to see how it looks as well as find photos from people who have built their own PCs in that case. People often upload their finished builds to PC Part Picker and when you view a part on PC Part Picker down the bottom of the page it will show you "Builds using this part" with photos people have uploaded.
Facts.
https://linustechtips.com/topic/1452168-pc-3d-model/#findComment-15545167
There is always a way. I have compiled few ideas from freely available parts on GrabCAD and Thingyverse. The selection is very limited, but has worked so far. What I have going for me tho: 10+ years experience in 3D modelling, have access to software that allows compiling parts into assemblies
That is only half the battle. After which I would have to use a rendering environment to set up materials, lighting, photorealism effects etc. Even then the resulting picture wont be as "good" as some people want
https://linustechtips.com/topic/1452168-pc-3d-model/#findComment-15545212
