This happened a while ago and I have been ignoring it for the most part but its getting really annoying now. A few months ago I noticed I had lower frames than usual (about 100+ less) and frame drops/stuttering while playing SOME games and after looking through HWiNFO64 I noticed my GPU was only drawing 40-50% power, but was running at 100% utilisation. The temperatures of the GPU also stayed below 70C with fans on low. Asked someone a while ago who said it is most likely not hardware failure as the power draw loss only occurs on some games rather than system wide.
PC specs
i5 9600k
Asus Z370-G motherboard
32gb 2666MHZ (2x16gb)
500gb SSD + 1tb HDD
ASUS ROG GTX 1080 8GB
550W Gold PSU
More details:
CS:GO: GPU draws roughly 70W of power, CPU draws roughly 30W.
Tarkov: GPU draws 160-180W of power, (don't have one of CPU - can get if needed).
Rust: GPU draws roughly 90W power.
Attempts to fix:
- Messing around in power settings of both nvidia control panel and windows settings.
- Messing around with settings in game
- Completely wiping my SSD and unplugging my hard drive - problem still occurred.
(can provide screenshots of hwinfo64 if needed)
Any help on diagnosing the problem would be appreciated.
https://linustechtips.com/topic/1450843-gpu-sometimes-not-drawing-enough-power/
well that should tell you that it is not hardware problem. its the game pr oblem. i have the same problem with rust
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
So what does it do with benchmarks, some actual testing rather than a game?
Yeah the only problem is it didn't used to happen, and now some games are unplayable due to the game stuttering constantly/extremely low fps.
