Mixer not having any sound output
Kanna
Heya, I got my hands on this old Mixer, like really old and I hooked it up and it powers on but I can't seem to get any output from it, it just is blank. And do note that I'm not anywhere close to good at this stuff, also I have a 12vDC cable instead of 18vDC, could that change anything?
Reminder⚠️
I'm just speaking from experience so what I say may not work 100%
Please try searching up the answer before you post here but I am always glad to help
try plugging into main mix out instead for the output
Sorry I probably edited my post. Refresh plz. Build Specs Below.
System
  • CPU
    Ryzen 9 5900x
  • Motherboard
    ASUS ROG STRIX X570-F
  • RAM
    32 GB (2X8) Trident Z Neo 3600MHz CAS 16
  • GPU
    ASUS ROG STRIX RTX 3070
  • Case
    Corsair 4000D Airflow
  • Storage
    Sabrent 1 TB TLC PCI 4.0 NVMe M.2
  • PSU
    NZXT C850 Gold PSU
  • Display(s)
    MSI Optix MAG342CQR 34" UWQHD
  • Cooling
    Corsair H100i RGB Pro XT 240mm
  • Operating System
    Windows 11
1 minute ago, Bad5ector said:
What happens if you plug into the Main Mix Output instead of using Tape Out?
I would have to find cables then so hold off a bit
Reminder⚠️
It looks like you have the cables already
Unless I'm assuming wrong... I thought those RCAs were plugged into your sound system.
EDIT: I'm dumb... those are unbalanced vs balanced.  Yes you need a cable. As you were... nothing to see here lol.
I seem to not have any cables so I will have to get my hands on some
Reminder⚠️
Manual says/shows tape out is connected to main mix out.
https://www.altoprofessional.com/downloads/S-6_e.pdf
Do you get anything on the vu-meters? Or the channel's peak indicator it you overdrive it?
F@H
GPD Win 2
I read the manual and tried multiple ports, for my microphone, nothing on the VU meters or peak
Reminder⚠️
What microphone is it?
And yes giving it 12V DC instead of the expected 18V AC could cause it not to work properly.
F@H
GPD Win 2
It's some unbranded mic that I know works, used it for some CD player before to hook up. Okay I will try to get my hands on a 18V AC, also that was a big mistake on me I thought it said DC on the mixer too, welp could that have fried it or something additionally
Reminder⚠️
