Compatible Parts
I am thinking of building a new system soon and I would like to know if a Gigabyte G1. Sniper 5 would be fully compatible with a Corsair 750D. It would be perfect if the board did not overlap the cable management grommets.
Yes, it'll fit.
The G1 Sniper 5 is an E-ATX (Extended) Motherboard, and being that the Corsair 750D Chassis is huge, it supports E-ATX Motherboards.
Also, nothing to worry about as far as covering the cable management holes + grommets. It might cover a couple, but not the main ones to get you great looking cable management.
Beautiful board btw. Every time I've ever built with it, it was pure enjoyment. Mainly the aesthetics. ![]()
It's a standard ATX board. It will work fine in the case (perhaps look small in the case); Other than that, nothing wrong. It's an ATX 'nuff said.
No, actually.. It is not a standard ATX. As I mentioned, it's E-ATX.
