I had a power surge recently and i had to get a new psu, after connecting all the wires everything turns on except the gpu, the fans aren’t spinning and it’s not displaying anything on the screen, i’m worried the gpu might have been killed by the power surge even though all my other parts are fine. PLEASE HELP ME!!!
ignore the cables i’m just trying to get it to work then i’ll manage it.
https://linustechtips.com/topic/1447924-no-post/
Possibly relevant additional context:
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1447924-no-post/#findComment-15513062
Just now, Owrw said:
i’ve already fixed that issue.
You connected a mystery cable to a mystery header because it "fit" so not necessarily.
https://linustechtips.com/topic/1447924-no-post/#findComment-15513068
Bruh the thing is not even secured... not sure how much I trust the quality of this build especially when you were just randomly plugging things into whatever fits...
Try a different PCIe slot that will fit a full sized card and if it doesn't post, it's likely toast.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/1447924-no-post/#findComment-15513074
In fairness, I wouldn't bother with the screws on the PCIe bracket either if I was removing the GPU and putting it back in a lot for troubleshooting. It shouldn't make a difference.
https://linustechtips.com/topic/1447924-no-post/#findComment-15513079
I mean yea... though the card torquing the heck out of the PCIe slot isn't going to help when troubleshooting a no video scenario. At least put one screw in since it's sagging to almost the next slot down.
https://linustechtips.com/topic/1447924-no-post/#findComment-15513610
it’s barely sagging 😂 stop over exaggerating the card is very light mate😂😂
https://linustechtips.com/topic/1447924-no-post/#findComment-15513742
