Hi guys, are all the pieces compatible with each other ? , before buying
First the motherboard : Gigabyte x570s aorus master
Second cpu : Amd ryzen 9 5950x
3 Cpu Cooler : Corsair icue h150i elite capellix liquid cpu cooler 360mm
4 Memory : I need to go for 64gb better than 128 : G.skill trident z royal series 32g (2x16) ddr4 4000mhz cl 18-22-22-42
5 Gpu : can i go for 3 gpu in 1 cpu ?
1:  AMD Radeon™ RX 6950 XT Desktop Graphics Card
2- AMD Radeon™ RX 6650 XT Desktop Graphics Card
3- AMD Radeon™ RX 6500 XT Graphics Card
6-storage : ssd *4of them  : SABRENT 4TB Rocket 4 Plus NVMe 4.0 Gen4 PCIe M.2 Internal SSD Extreme Performance Solid State Drive R/W 7100/6600MB/s (SB-RKT4P-4TB)
7-power supply : Corsair AX1600i 1600 W 80+ Titanium Certified Fully Modular ATX Power Supply
8-case
Lian Li O11D XL-W ATX Full Tower Case
9- can i add fans in the case ?
and how many
https://linustechtips.com/topic/1446743-building-a-first-gaming-pc/
1. The 6950xt alone alone can output to 3 monitors.
2. Amd gpus afaik aren't profitable in mining at all compared to nvidia gpus
3. Sli crossfire has been dead for a while, you probably won't find a recent game that supports it.
Let me rephrase myself, this system is a large waste of money.
The 5950x gets outclassed by the 12900f in gaming and is usually cheaper
X570 don't have a lot of benefits to b550, although maybe here since you want 3 gpus, still probably not worth the money of the mobo though
The corsair aio is probably overpriced and some like the ek ek can be found for cheaper
I'm confused on your statement on the ram, more ram is "better", but you most likely won't see more than 16gb of utilization in games
See previous statements for gpus
Do you really need 16tbs of storage?
You mean nvidia gpus  is better for gsming and also mining
i will go for amd process
yes i need 16 tbs at least
because i am gonna download some big games
like
genshin and warframe and ark  and minecraft and other
and some programs
 not just for gaming
also  editing and programing stuffs and other ideas
like
and some programs
 not just for gaming
16tbs is excessive for literally any desktop pc
Why do I get the impression that the dude's some Saudi prince who has no concept of what money is...
If you want to OC memory don't look past 32GB. You either have the fastest memory in the world or more than 8GB of it.
no
6800XT
If you're gonna spend  over $2.5k for storage at least get one that makes wooosh noises
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
no
6800XT
i am not a saudi prince , if i was prince i can buy those easily ,  yes i ilive in saudi arabia , but not all saudi that rich 3000~ 12000 $  ,  Only The royal family and the princes , they are can buy a planet xd or maybe 100x hotel
no
6800XT
why i cant go for 3 gpus in 1 cpu , did u test it before for Accuracy and clarity or dont gonna work
like
and some programs
 not just for gaming
I'm not here to help much but I'm just wondering how you expect to download that many games, you can download warzone 160x over
i am gonna download some of my favorite games , at leats 20 game , and some programs
Yes. I CEO of GPU. Tested all GPU. 3 GPU no work. 1 GPU yes work.
