Hello,
I had to move countries earlier this year for my studies. Upon arriving here I was given an old computer from a friend as I had left my computer back home for my little brothers to use.
The specs of this computer:
i5-3740
12GB DDR3
GTX 750ti
The problem I am facing is very simple. **Whenever I download something as a single file (from a browser for example) everything is completely fine**, I get 20 megabytes down and all is well. But when I try to download things from Steam or Epic games (Games that need decompressing as the are being downloaded) the download **speeds drop to almost zero and the download stops** at random intervals as well as the disk speed. What exactly is the issue?
The internet at the house I am currently staying at is very fast (I get 20mb down on steam) so could it be that the internet is too fast for the processor or disk to decompress? Or is the issue with the CPU/Disk anyway?
One thing I have noticed is that when I download something on **Linux it doesn't have this problem!** But on every single edition of Windows that I've tried has had this issue, even an extremely lite low ram usage custom windows.
Please help, thank you.
https://linustechtips.com/topic/1445608-problem-downloading/
4 minutes ago, TheTimeCrust said:
Or is the issue with the disk anyway
Yes, that would be my very first guess. Steam can preallocate games before actually downloading begins and if you have issues with your disk (I assume this is a HDD) then it wouldnt complete or take forever.
https://linustechtips.com/topic/1445608-problem-downloading/#findComment-15496596
What type of SSD/HDD do you have?
Can you do this test with both your Windows and Linux system: https://www.nperf.com/en/
What exact results do you get for both systems?
OS: OpenBSD -current WM: Polybar -- bspwm -- dmenu -- picom Components: Intel 12700KF -- G.SKILL RIPJAWS @4000 CL18 -- ASUS Dual Radeon RX 9060 XT 16GB -- ASUS ROG STRIX B760-G GAMING WIFI D4 -- JONSBO Z20 black -- ARCTIC F14 -- bequiet! SYSTEM POWER 10 550W -- DeepCool AG500BK -- Kingston Renegade G5 1TB and Samsung 9100 PRO 1TB Mouse: zalman ZM-GM7 Display panel: UltraGear 34G630A-B Headphones: Kawai SH-9 Webcam: Microsoft LifeCam HD-3000 Keyboard: HP desktop 320K Microphone: Trust GXT 259 RUDOX Camera: Fujifilm X-M5
https://linustechtips.com/topic/1445608-problem-downloading/#findComment-15496609
Its a new adata ssd that I bought not too long ago
https://linustechtips.com/topic/1445608-problem-downloading/#findComment-15496615
I'm using Steam on FreeBSD, usually you're either downloading, or your SSD is doing work, or both at the same time. But I think on all operating systems there are definitely times when you don't see any activity in download or SSD. I don't know if this is something abnormal per se that you need to troubleshoot, unless you find that your game installations on Linux are much faster than on windows, have you timed this multiple times?
https://linustechtips.com/topic/1445608-problem-downloading/#findComment-15496623
230 download
30 upload
22 ping
same for both operating systems
https://linustechtips.com/topic/1445608-problem-downloading/#findComment-15496763
The only issue is that there aren't "times" where it stops the download, it just always is doing it on windows but on linux its a constant download that doesnt drop at all
https://linustechtips.com/topic/1445608-problem-downloading/#findComment-15496766
Can you still download something on windows? Are there times on windows when it does download?
You can try to reinstall steam (but delete all your local steam folders/settings/data first).
https://linustechtips.com/topic/1445608-problem-downloading/#findComment-15497038
