Question about Lian Li O11 Air Mini
Solved by fonzz1e,
@_Froyofrom your profile, yer using nr400
- o11 air mini, 400 mm x 288 mm x 384 mm (L / W / H)
- nr400, 411 mm x 210 mm x 411 mm (L / W / H)
base on the above specs, o11 air mini should be slightly thicker & shorter
i would say it's definitely an upgrade from yer nr400
- more options to mount 240/280 aio
- o11 air mini will provide more air to yer gpu if u add fans below
example build from reddit (using atx mobo)
https://www.reddit.com/r/lianli/comments/r8ennk/first_o11_air_mini_build_12700k3080_full_parts/
