We gonna need more than just a link. Do all the other 4 required fields when posting a thread.
On paper a bad build.
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
https://linustechtips.com/topic/1444194-first-build/#findComment-15487055
Budget (including currency): 1500euros can be a little bit more
Country: Austria
Games, programs or workloads that it will be used for: Games:mostly popular titles like warzone,apex etc.  For 1080p gaming and prob some web designs or game designs.
https://pcpartpicker.com/list/Whq6qm This are the parts that I think are good for what I want to do. I also want to mention that this is going to be my first build. I don't have a exact date when to build it.
https://linustechtips.com/topic/1444194-first-build/#findComment-15487079
PCPartPicker Part List
CPU: AMD Ryzen 5 5600 3.5 GHz 6-Core Processor  (€203.90 @ Alza)
CPU Cooler: Deepcool GAMMAXX GT A-RGB 64.5 CFM CPU Cooler  (€34.90 @ Alza)
Motherboard: Gigabyte B550M AORUS ELITE Micro ATX AM4 Motherboard  (€106.90 @ Alza)
Memory: G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  (€62.90 @ Alza)
Storage: Samsung 970 Evo Plus 2 TB M.2-2280 NVME Solid State Drive  (€203.90 @ Alza)
Video Card: Gigabyte GeForce RTX 3070 LHR 8 GB EAGLE OC Rev 2.0 Video Card  (€678.90 @ Alza)
Case: Corsair 4000D Airflow ATX Mid Tower Case  (€114.90 @ Alza)
Power Supply: Fractal Design Ion Gold 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (€97.90 @ Alza)
Total: €1504.20
Generated by PCPartPicker 2022-07-19 14:26 CEST+0200
If you want you can save money by getting a 6600 XT. More than enough for 1080p, but the 3070 is better if you plan on getting a 1440p monitor in the future.
https://linustechtips.com/topic/1444194-first-build/#findComment-15487088
Something like this should keep you comfy. No idea about the Austrian market, PCPartPicker only shows one site:
CPU: Intel Core i5-12400 2.5 GHz 6-Core Processor  (€209.90 @ Alza)
CPU Cooler: Deepcool AK400 66.47 CFM CPU Cooler  (€34.90 @ Alza)
Motherboard: MSI PRO B660M-A DDR4 Micro ATX LGA1700 Motherboard  (€152.90 @ Alza)
Storage: Western Digital Blue SN570 1 TB M.2-2280 NVME Solid State Drive  (€87.90 @ Alza)
Storage: Western Digital Blue 4 TB 3.5" 5400RPM Internal Hard Drive  (€83.90 @ Alza)
Video Card: Sapphire Radeon RX 6750 XT 12 GB PULSE Video Card  (€657.90 @ Alza)
Case: Cooler Master MasterBox Q300L MicroATX Mini Tower Case  (€50.90 @ Alza)
Power Supply: SeaSonic FOCUS GX 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (€115.90 @ Alza)
Total: €1457.10
Generated by PCPartPicker 2022-07-19 15:38 CEST+0200
https://linustechtips.com/topic/1444194-first-build/#findComment-15487185
Country: Austria/Uk
So are you in Austria or the UK ? as that will affect what stores you are buying from.
https://linustechtips.com/topic/1444194-first-build/#findComment-15487213
$130 LC for a 5600X ?!?!?!?! That the epitome of "overkill". That 5600X does perfectly fine even with stock AMD coolers, but even if you want to go overboard NH-D12 / NH-D15 are more than enough. Best solution is save yourself $100 on the cooler and them to the GPU for a 3070.
| Ryzen 7 5800X3D | Arctic Liquid Freezer II 360 Rev 7| AsRock X570 Steel Legend |
| 4x16GB G.Skill Trident Z Neo 4000MHz CL16 | Sapphire Nitro+ RX 6900 XT | Seasonic Focus GX-1000|
| 512GB A-Data XPG Spectrix S40G RGB | 2TB A-Data SX8200 Pro| Phanteks Eclipse G500A |
https://linustechtips.com/topic/1444194-first-build/#findComment-15487468
*** Threads merged ***
Multiposting and dumping threads is considered spamming. Please use this one thread, we have Edit function.
As for 5600 vs 5600X, you don't really gain anything with X. That CPU is the older of the two.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1444194-first-build/#findComment-15487576
3 hours ago, Avocheeseado said:
https://at.pcpartpicker.com/list/JMYPgb
Honestly couldn't recommend hard drives in this day and age. A 2TB nvme fits within the budget, and there may even be space to upgrade to a 3070 or 6750xt
i mean hdds arnt that bad. i have one as a games drive cus i cant afford to spend over 100 pounds on it
https://linustechtips.com/topic/1444194-first-build/#findComment-15487594
yea but 25euros not that big of a deal to be honest.Prob not even 25euros
https://linustechtips.com/topic/1444194-first-build/#findComment-15487604
your right about the 130e LC. I've already put a 3070 on the pc part list.
https://linustechtips.com/topic/1444194-first-build/#findComment-15487615
As it happens, I'm doing research for upgrade and have looked things up. For $25 more you get minor (depends bit on test, but generally within percentages) performance boost and some 5C higher temps. Your money, but I wouldn't spend more here with such small benefits.
https://linustechtips.com/topic/1444194-first-build/#findComment-15487621
Ok I will listen to your advice since I am new to pc's but now I have another dilema should I keep that motherboard or should I put more money to it to get smh else. I was looking at asus rog strix b550-A here's a link:https://www.amazon.de/-/en/dp/B08KBSRYGF/?coliid=I2PXYDUFJ6OBU&colid=1Y7G4M9I46SK7&psc=1&ref_=lv_ov_lig_dp_it_im (it's the german amazon)
https://linustechtips.com/topic/1444194-first-build/#findComment-15487637
