Storage for Nas
2 hours ago, Yous34 said:'m a total newbie in pcie splitting,can you explain this to me? from what i know i thouhg thst a x16 could be always split equally,tho that raises a quation,can i split an x16 in 2 x8 and get 2 low profile x8 to dual m.2s ?
The cpu and mobo has to allow the lanes to be split, they can't just be split without the board being setup for it. Intel limits the consumer socket to x8 x4 x4 splitting on supported chipsets, so your combo can do x8 x4 x4 max. If you get a 4x m.2 card you can only use 3 ssds on it.
The other option is to get a pcie to m.2 card with a pcie switch chip. This allows for it to work on boards without bifurcation support, and allows 8 drives on one x16 adapter. Here is an example. https://www.highpoint-tech.com/gen4-nvme-m2. Problem is there pricey.
