Gigabyte disappoints with there 5600xt cooling
ARC_
I have gigabyte rx 5600xt triple fan edition purchased as early it was launched and have a thermal throttling issue from 2 years made RMA multiple times but same problem never but gigabyte products their quality is crap
2 minutes ago, xDD said:
I have gigabyte rx 5600xt triple fan edition purchased as early it was launched and have a thermal throttling issue from 2 years made RMA multiple times but same problem never but gigabyte products there quality is crap
That's a bold claim without mentioning your case and fans.  We can't possibly know its a card problem or poor airflow in your case.
Router:  Intel N100 (pfSense) WiFi6: Zyxel NWA210AX (1.7Gbit peak at 160Mhz)
WiFi5: Ubiquiti NanoHD OpenWRT (~500Mbit at 80Mhz) Switches: Netgear MS510TXUP, MS510TXPP, GS110EMX
ISPs: Zen Full Fibre 900 (~930Mbit down, 115Mbit up) + Three 5G (~800Mbit down, 115Mbit up)
Yeah, it's pretty common. I had issues with thermal throttling in windows, turned out it would thermal throttle at 85°C in the die but never push the fan above ~50%, some custom fan curves (pushing 100% @75°C) and it began to behave itself.
i my situation fans often run at 100% speed and their crap fans goes dead within few months, i have to send them for RMA again where their bold claim is that i use it for mining which i never do.
i think they use to tell this to everyone in a way to get out of their poor design quality and cheap Chinese fans. Gigabyte has terrible thermal performance
