Safe cpu voltage offset for 5800x3D?
40 minutes ago, Origami Cactus said:yeah, 140mm. My previous 3700x was 90c with a 92mm one, so I went all out for the 5800x3D lol.
Quite happy with 80c at load tbh, not going to change the case to fit a larger rad.
About the LLC; I have no idea what it does. Seems to increase voltage to prevent droop, but I am after the lowest voltage, so seems counter intuitive, especially as I don't have stability problems, so no droop for now.
Well the way transistors work.....
You have millions. Some do not operate. Even with a default cpu.
A low volt hang up is the result of too many transistors that are not operational.
Some are used for per core, Some are used to handle memory and Some are used for IO.
So the lower the vcore, the less transistors operate. And as a result you can produce lower cpu scores during certain benchmarks to demonstrate that.
Vcore leakage is a real thing. The higher the temp, the more transistors leak.
So it can be a hand to hand thing, lower temps lower ccore. You just gotta find that middle ground.
I would try base default frequency with vcore on auto and give it a load. See what it settles at and increase the frequency based on that voltage.
