Where to buy keyboard parts (Cases, plates, pcbs ...)
Solved by GuiltySpark_,
Going to just first link most of the sites from my bookmarks after getting into keyboards.
https://drop.com/mechanical-keyboards/drops/?
https://www.gloriousgaming.com/collections/keyboard
That being said, you're really not going to find plates and PCB's across all different sites that will work together. If you buy a case for example, PCB's and plates that work will be listed and likely need to be bought from the same place.
