m.2 E Key for WiFi; Plug and Play?
Solved by Needfuldoer,
You'll need antennae, especially if the card was pulled from a laptop (which use wires around the screen for WiFi antennae).
If anything, you should be able to find short adapter cables that can plug into the card and give you regular thread-on "SMA" connectors on the outside of the case. Then you can just get some router antennae off Amazon or eBay, since many routers (and PCIe WiFi cards) use SMA connectors for their antennas.
