Is using the 8 pin connectors from 2 daisy chains (6+2 and 6) fine for RTX 3080?
Solved by Poinkachu,
3 minutes ago, Shimitan said:Thats also the conclusion I'm drawing, but I need to know if using two 6+2 and 6 pin connectors, using only the 6+2, is even a stable solution until I get my hands on two seperate 8 pin connectors. Like, I read that having two seperate 6+2 pin connectors is fine, but how about when those 6+2 pin connectors are in a daisy chain? Does that change anything?
It's fine leaving the daisy chain part dangling, if you want to be tidy, use zip ties so it doesn't wiggle around.
Just don't tighten too much.
